Looking for some opinions on this one, I think its carb related (maybe my main is loose) or the valves need to be adjusted since I have close to 10-15 hours on it already.
New rebuild done approx 10-15hrs ago: 2004, 12:1, hotcam 2. Ported, +1 ex valves, new valves all the way around and springs. Running a dasa ring with 06+ uni filter and open airbox, carb is 190 main, 50 pilot and 2.5 turns out as well as HRC needle 3rd clip. I just did the air filter, before it had stock sized uni with same jetting.
Was riding fine all day, then hit a VERY bad section of whoops but I was flying over them. Got tired and slowed down and then noticed the bike didnt want to run unless I had throttle and was sputtering. Let off throttle and it shut down and took a bit to start up.
Later climbing a hill at the top I let off a good bit when i crested and it sputtered and died. At this point I raised the idle slightly from about 1100 (have a tach) which was fine before to 1400 (stock says 1600 but DANG thats high!).
Issue seemed to be better, but then was flying down a road topped in 4th and downshifted to 2nd and engine braked and bike shut down? Grabbed clutch and kept rolling them bingo it pop started with ease.
I havent taken it apart yet, no coolant leaking or boiling or missing so that rules out things like head gaskets and such. IDK? Stator would make me think it would be ok higher rpm or lights would flicker bad idling but they dont. Seems strange...
